I am replacing my filter and backwash valve, but my current system uses a 4 port multi-valve. The physical layout is shown in the figure below. I cannot find a replacement for this type of valve, so I want to use a modern backwash valve.
The new backwash valves have the pump inlet and pool outlet on the same side of the valve. Would adding a 180 degree turn from the outlet of the multi-port to connect to my heater reduce my flow enough to cause problems?
I suppose I already have a 180 turn in my current system (multi-port to bottom of filter), and I would be able to eliminate the second valve that diverts to the drain. Perhaps this compensates for the new 180 turn?
Any advice is appreciated.
