reebok
0
WaterWoman said:I did the FC Loss Test last night. I had a drop of .2 between 8:30PM last night and 5:30AM this morning, so I assume that's good? It said 1.0 or less drop is OK, right?
I am still waiting for the CYA in the sock to dissolve (which is hanging near a return), but I am getting FC readings of 0 at the end of each day. I'm not sure I am adding enough bleach, but am doing what the pool calculator is telling me, provided I am using it right. It says my FC goal should be "2 to 6," and with the target set at 3 (which is where it was when I first opened it--I didn't change it) the amount of bleach it recommends I add is bringing me to the 3.4-3.6 range (it was 3.4 just now after being 3.6 last night). I assume it is all being eaten up by the sunlight since the FC Loss Test seemed OK, and the stabilizer hasn't dissolved enough to have any effect yet. Is this normal for a newly filled pool? Am I adding enough bleach? Should I raise the target on the pool calculator or is this sufficient?
The pH is holding steady at 7.4, and the TA at 70. I haven't tried retesting for CH yet, and testing for CYA seems useless until the stuff in the sock dissolves (right?). So, is there anything else I should be doing right now?
ETA: I should probably add that it's pretty hot here right now. Today's temp is predicted to be 97, and it's forecast to range anywhere from 94 to 101 over the next 10 days. The pool gets a full day of sun. The shallow end is shaded after about 3-4PM, but the deep end is in sun all day from about 7-8AM until about 6-7PM. Don't know if that makes any difference, but thought I should note it.
ETA again: One more question about the pool calculator... When I first open it, it says my FC Goal is "2 to 6" like I said above, but once I fill in my "Now" values and click "Calculate," the FC Goal changes to "1 to 3." Why is that? Is it because of the 0 CYA value? Or something else? Just want to be sure I'm getting the correct results.
your overnight fc loss is fine. your huge problem is you're letting the fc get to 0. you're supposed to shock if you let that happen. yes you're losing it to sunlight. wait a week after the cya dissolves to test. different things affect the recommended ranges for the calculator. if you change your cya level it will change the recommended fc level. I highly recommend you read pool-school/ pool chemistry section because it will answer these questions you have and will give you a much better understanding of pool chemistry which will make the calculator make more sense.
