Results 1 to 9 of 9
Thread: above ground pool ideas?
    hawkeye's Avatar
    davenport,iowa
    118
    hello i have had a 18 ft round 52in deep pool for 3 years and i still havent finished around the bottom outside of the pool for like a border of rocks coming around the pool for drainage and spashing it gets muddy when im vacumming and stuff i thought about coming 2 feet out all the way around with like river rock not the pea gravel stuff to soft anyone have any pics of your pool with something similar? so i can get somes ideas would like to suprise my wifr by finally getting it done im have a grass yard so any pics would be cool so i can get a idea.............thanks mike
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Butterfly's Avatar
    South Carolina
    10,045
    Re: above ground pool ideas?
    Hey Mike,
    If you have some pix to post, the ideas will flow in
    Some of us ( ) are really visual
    You're done SLAMing when:
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    I have river rock around our pool. I think it looks nice here on the other side of Iowa.[attachment=0:279r970y]IMG_3931.JPG[/attachment:279r970y] This picture is just after our install,the grass has filled in now.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    I just put some river pebbles and stuff around mine.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I put in some edging and white marble chips. Oh - make sure to put landscape fabric down first, whatever you do. Sure cuts down on the weeds.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I'm not sure I have a picture anywhere or not. We used 'Class 5' fill mechanically compacted - it's what they make parking lots out of. River and pea rock has such a tendancy to catch seedlings from trees and weeds and then junk is growing in between and it's a mess. We have a shallow well in our yard so no chemicals can be used anywhere due to runoff - also have Koi ponds so drift is a concern too.
    It's edged with scalloped edger. I put pots of flowers/shrubs ON this, but no plants in it - that's the idea. Ours is about 28-45" away from the pool edge, depending on which side.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    hawkeye's Avatar
    davenport,iowa
    118
    hope this pic shows up well this is it thanks guys for the pics you sent any more ideas would be cool too!
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    Jul 2007
    Northern NJ
    299
    The majority of us have done some kind of rocks, it seems. I have pink marble rocks around mine and a drainage pipe also.
    Here is a pic:
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Very nice, Nicole!!
    Intex 8110 SWCG
    "Fear the Schnauz!"
