My son just bought a house with a vinyl liner inground pool and the pool is leaking water to the tune of about 3 inches overnight with the filter off. He let it go until it stopped and it stopped just below the skimmer face plate. Aha, must be the skimmer gasket I thought! Filled the pool to mid skimmer level and squirted the food die all around the skimmer face plate. No dye got sucked in. OK must be in the liner along the level of water just below the skimmer face plate. Went around the entire pool squirting food dye all along the water level and just below. Nothing go sucked in. The water is above all the return lines so I don't think its a plumbing problem in the return lines. We squirted dye around the light fixture which is also below the water level and it also looked OK. I am building a pressure testing stick tonight to check the skimmer plumbing lines to see if it holds pressure. I'll let you know how that goes.
My problem is that on my pool filter I have a handle that shuts the main drain or the skimmer or if I keep the handle centered it feeds water from both the main drain and the skimmer. His pool is older and has large outdoor type faucet handles that have no markings so I am not sure what they do. I have attached a pic. I also have two separate lines for main drain and skimmer. I have read in these forums where sometimes BOTH the main drain and skimmer lines meet at the skimmer with only one 1 1/2" line going back to the filter. How do I know which design he has? I can screw the pressure testing stick into the skimmer but if I cannot close the skimmer at the filter I can't pressure test it, right?
The ironic thing is that this son helped me run two new return lines that were leaking in MY POOL just a month ago! Well, if we have to replace his skimmer line at least he will have some experience!
I could not get the picture to upload. Any advice you can provide to help me find this leak would be greatly appreciated.
