I have my ahh-some as I have learned here that I need and will be doing a purge soon. In reading the directions on the ahh-some website it says to add the 3tsp ahh-some directly to the water and run with the filters in place. The water will foam up, then remove the filters and rinse off, then put back in the spa water and run all pumps for 30 minutes. It then says filters will be cleaner than ever.
Four questions:
1) can I run my Hotspring Grandee without filters in place? I thought I read in the Hotspring manual not to run without filters in place.
2) Will this have any negative effect on the ACE SWCG cell? Should I turn off the output and remove the cell from the water prior?
3) Should the tri-x ceramic filters be in the water as I dose the ahh-some or will they get gunked up with the purge?
4) In reading the ahh-some instructions, it seems that ahh-some might make a great separate filter cleaner by mixing a separate batch to soak the filters. Is this done?
Thanks for any insight.
Four questions:
