It's pretty common knowledge on here that bottles of sodium hypochlorite (bleach, liquid chlorine) will lose potency over time. It will lose strength faster the higher the concentration. It is often mentioned that heat increases this process so it's recommended to store your bottles in a dark/cool location.
In contrast, once chlorine is added to the pool it is explained that the chlorine loss in your pool is only impacted by two things: UV rays (sun) and organics (algae). The heat of the water is not a factor, which is a reason why the OCLT works no matter your pool water temperature.
In any event, the mystery to me is why does temperature matter when chlorine is in the bottle, but doesn't matter when it's in the pool?
