Hi guys some questions id like to ask, test results below:
- Can high CYA like 70 ppm cloud pool water?
- Do you think i should shock with MPS?
- Should i also add algecide to pool whilst shocking with MPS? How much MPS should i use?
- Any other recommendations for treatment?
THanks a 1000
Test Conditions as such:
Water Clarity: Dull
Temp: 30 C
pH: 7.5
TA: 80
CAL: 140
FCL: 2.6
TCL: 2.9
CYA: 70
Fe: 0
Cu: 0
Pool Size: 20,000 gallons
THanks a 1000
Water Clarity: Dull
Temp: 30 C
pH: 7.5
TA: 80
CAL: 140
FCL: 2.6
TCL: 2.9
CYA: 70
Fe: 0
Cu: 0
