Thread: Just opened pool Here are my numbers
    May 2016
    Rocky point/new york
    34
    Hi All, I just opened my pool for the year. Here are my test numbers. Seems like I just need to add some stabilizer and Baking soda???
    FC - 12.5
    CC - 1
    TC - 13.5
    Cal - 350
    Alk - 90
    PH - 7.5
    CL/BR - 5/10
    CYA - 40
    Thought???
    Thanks for all you guys do!!!!
    Joe- Rocky Point, NY.Vinyl, 21x36 Free Form inground 20k gallon pool with Pool pilot DIG-220 salt system, STA-RITE system 3 S7M120 pool filter, Polaris 360, Intellipro variable speed P6E6VS4H pump, an electric heater and Aqualink RS power center.
    Jun 2014
    17,692
    Re: Just opened pool Here are my numbers
    Not bad at all. I wouldn't add any baking soda at this time. Focus on the FC and even increase it to "16" which is the SLAM level based on your CYA of 40. Best to just do that now and ensure you pass a rock-solid SLAM (quickly hopefully) since your CC is a bit elevated. I suspect it won't be long before you pass all 3 SLAM criteria (SLAM link below in my sig).
    Welcome back to another swimming season.
    May 2016
    34
    Quote Originally Posted by Texas Splash View Post
    Thank you so much. I'm going to test again today. The pool is crystal clear. Just want to double ck the numbers.
    May 2016
    34
    My test today
    FC - 12
    CC - 1
    TC - 13
    Cal - 300
    Alk - 90
    PH - 7.5
    CL/BR - 5/10
    CYA - 50
    Jun 2014
    17,692
    Very good. Since you confirmed your CYA to actually be slightly higher at 50, your SLAM FC level is 20. So you'll want to increase the FC to 20 and perform your season-opening SLAM to ensure you are algae-free for the summer. The pH should be between 7.2-7.4 prior to a SLAM, and you are on the upper side of that. Part may be because your FC is already over 10 which makes the pH show as higher anyways. But if you want to double-check, you can let the FC drop under 10 just long enough to confirm pH then crank FC up to 20.
    May 2016
    34
    Quick question. Is it safe to swim right now?? We have 2 pretty hot days over next 2 days. Then a cold spell. Kids are dying to go in.
    Thanks again
    joe
