Thread: What should I pay someone to vacuum and brush my pool.
    Sep 2011
    Atlanta Ga
    327
    I've got some arthritis problems and want to cut back on physical work.
    I'm going to continue doing the chemicals but I am paying someone to come twice a month to vacuum and brush my pool.
    What should I pay for this?
    I am in Atlanta, which I think has average costs for labor. Cheaper than California but more expensive than rural Alabama.
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    Re: What should I pay someone to vacuum and brush my pool.
    I would guess anywhere between $50 and $100 for two trips a month. However, it might be just as cheap in the long run to get some type of automatic cleaner and let it do the work for you. Maybe a Polaris or a suction side cleaner or one of those more expensive robots that run on their own without using the pool equipment.
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Psoriatic arthritis here. When I fired our pool guy my lawn service owner was here. They don't maintain pools but on the spot said they could brush and empty skimmer baskets when here anyway for only $5 more. I have an enclosure though, and it would still leave vaccum and pump basket. But, if you have a lawn service it may not hurt to ask them.
    Edit: They no longer brush, but only empty the usually already empty skimmer baskets but no charge. Just lets me be a little more lazy
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Jun 2016
    Walhalla, SC
    275
    If it's a young kid that lives nearby, and all they're doing is a quick brush and vacuum, I'd say around $15-20 per cleaning, since it should take less than an hour for a decently thorough job (more if your pool tends to collect a lot of debris). If they lived more than 15 minutes away, I'd pay a bit more. If it's an adult you should probably pay a bit more too. Obviously if there's anything particularly challenging about it (half to walk a quarter mile just to get the equipment), pay a bit more for that. Could always combine it with some yard work to make it more worth their time.
    20x40 28kgal in-ground vinyl built 2011, liner replaced 2017
    Pentair Tagelus TA60D sand filter, Pentair SuperFlow 1HP pump, Intellichlor IC40 SWG, Dolphin Active 30i
    City water, TF-100 test kit + speedstir.
    Recommended Levels | Chlorine/CYA Chart | SLAM
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    What about getting a good robot? Since I got my robot there has been nothing to brush up on the bottom of the pool. Empty it once a week and you're good to go.
    I bought a Doheny's Discovery, same as a Maytronics S200, Dolphin Active20 and Dolphin Triton. Marina Pools has the best prices as of last report here, Maytronics cleaners
    More about my robot in my pool thread, link in sig. Also more here, Doheny's Discovery, S200, Active20, Triton owners club
