Thread: Good source for Boric Acid in Sacramento (or elsewhere)
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I have previously purchased boric acid from Duda Deisel as well as a few other eBay sellers for around $2 per pound delivered.
    I just discovered that eBay seller, prosupplyoutlet, has 25 lbs for $30.33 with local pickup in Rancho Cordova ($46.88 delivered).
    Super nice and professional outfit, easy Borates!
    For comparison, Sierra Chemicals in West Sacramento wanted $2.24/lb with local pick up. Nope.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    Re: Good source for Boric Acid in Sacramento (or elsewhere)
    check out a distributor for biodiesel chemicals, that is where I got mine. ( DudaDiesel.com > Biodiesel Supply Home Page)
    Walt Lukowski
    Southern California
    Salt water pool at 24000 gal. new whisperflo variable speed pump. 60 gal. per min.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yep, Duda Diesel is the most popular source for granular borates on TFP.
