Thread: Can I filter a pool that is not full?
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    My water level is below the skimmer and vacuum inlets.
    I have my valves set to only draw from the main drain.
    Assuming there are no leaks that would cause the pump to
    suck air in, can my filter run with the level this low?
    I know that's not the recommended situation, but I am
    wondering if it can be done.
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
    40,867
    Re: Can I filter a pool that is not full?
    Maybe ... depends if you can get the pump primed.
    BTW, your filter does not run, it just filters. The pump is what runs and moves the water
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Quote Originally Posted by MJCP View Post
    Yes it can if you get water to the pump.
    Support the site
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Got me
    Thanks for the quick reply
    Thx! for the quick reply
