Thread: 3 months into my rebuild
    Apr 2017
    sacramento CA
    147
    Hi joined the other day. I've been working on getting everything set up correctly and I think it's getting there. I finally have the right test kit. Here are my numbers for the last 3 days. Please let me know how it looks. I'm going to add a little acid tonight.
    Pool info in my sig.
    Thanks a bunch the dog
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: 3 months into my rebuild
    Looks good. You're going to want your TA lower, probably around 60. The lower TA gets the slower your pH will rise. It will slowly lower over time as you add acid to lower PH. Or you can actively lower it following this, Pool School - Lower Total Alkalinity
    Apr 2017
    sacramento CA
    147
    Thanks man. Appreciate it. I saw that article. I have not been running the spillway for the last couple weeks. So I'm sure that is the reason for the spike. A month ago it was about 20-30 points lower.
