Thread: Diverter Valve Dimensions
    Jul 2011
    St. Paul, MN
    244
    I will be replacing my pump soon so taking the opportunity to also redo my suction side plumbing. I would like to use Jandy or Pentair diverter valves, but I'm not sure if I have enough space. See the picture below. I have 3 suction side pipes (2 from skimmers, 1 from main drain) that are pretty close together. I do have room to push my pump farther away from the valves so that the valves could be staggered, but I'm still worried the diverter valves are too wide to fit.
    Does anyone have the dimensions on a 2-way diverter valve? I can't find anything online.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Diverter Valve Dimensions
    I just measured my valves. Mine are three-way, but I think the bodies are similar. 5" wide.
    Think in 3D. Raise or lower the center valve, or even install it in the vertical pipe, and then bring all the pipes to the same elevation before the cross
    Jul 2011
    St. Paul, MN
    244
    Thanks, Richard. The center to center spacing is about 5.5", so they should just barely fit next to each other if needed. And as you said, putting them in the vertical pipe would be a good option as well.
    A couple more questions:
    1. I will probably convert some of the pad plumbing to 2". Should I do this right where it comes out of the ground, at the valves, at the cross, or doesn't matter too much? Seems to me that as long as I use a 2" cross, then it doesn't matter too much.
    2. I currently have a gate valve in addition to the ball valve on the main drain line. I'm thinking its a good idea to keep 2 valves on the main drain for winterization purposes - extra insurance in case one of the valves starts leaking air.
    Richard320's Avatar
    Jan 2010
    20,312
    Upsizing to 2" where there's a lot of elbows and Tees is probably a good idea, but if the underground plumbing is 1 don't expect any huge increase in performance. A chain is only as strong as its weakest link and a pipe is only as big as its narrowest point.
    I know nothing about winterization. Where I live, we rarely even see frost.
