I've submitted this question to Hayward support and so far I get the standard answer which is no help. I know I am the "site tester" for this new pump but hopefully someone in the know can help me here.
I have the Tr Star variable speed pump with the tri Star Variable speed controller (not aqualogic). I am trying to find out if there is a way I can turn the power to the swim pure plus off and on using the TS variable speed controller. the controller has a digital timer to turn the pump on and off and I wonder if I can use it to tun the swg on and off as well. So the swg is only powered and operating when the pump is. I am trying not to depend on the flow switch only.
If there is no way to do that then is there a way the controller can trigger a relay when the pump turns on, and I can use the realy to turn the swg on and off. I am aware of the units you loop the pump wires through and they detect load and close a relay but I am trying to avoid something that size.
If I can't do either then I will just run the swg on a seperate digital timer. Thanks!!
