Thread: Calcium Level min a newly resurfaced pool
    May 2017
    hollywood fl
    1
    Just had my in-ground pool resurfaced w/diamond brite 2 weeks ago and was told not to add calcium as the level will naturally correct itself over the course of time. It's currently at 120ppm, range s/b 200-400. Any suggestions/comments?
    30x15 in-ground, diamond bright finish. Resurfaced 4/11/17
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Calcium Level min a newly resurfaced pool
    Welcome to TFP!
    I would raise CH to 250 ppm. CH does tend to rise over time. But, my pool etched the first winter due to low CH.
    Here is what SGM says, http://www.sgm.cc/html_Pool/HomeOwne...chemistry.html
    Be sure to register your warranty, http://sgm.smod.us/smodMain.php?sys=pub&pub=wif2
    Jan 2012
    'burbs of Augusta, Georgia
    8,556
    Quote Originally Posted by kona0729 View Post
    For you, being in FL, your CH will rise much slower than someone out west. You also have a lot of rain in FL which tends to cause pool owners to make occasional mini drains to prevent overfills. Those mini-drains will take some of your calcium out along with the water. If your water is too low in calcium it will leach it from the walls and weaken the plaster. You want to avoid that.
    Take it up to 250ppm.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
