hi guys,
I am fairly new to having and maintaining a pool. I took the advise of my father in law and Im not sure that I am off to a great start after finding this site.
My pool was uncovered during the winter and when I went to get it opened it was almost black. I had to replace the pump and started removing all the leafs and debris from the water. Taking his advise I poured 5 gallons of bleach into the pool and added two 3" chlorine tabs to the skimmer. Here is where I should mention that I have a SWG...
After adding the chlorine I began brushing twice a day and back washing, this wan on Friday and now on Tuesday the water is an opaque green(almost mint color). I brushed this morning before work and went home and back washed again at lunch.
When I leave work I am going to buy a chemical test kit, I live kind of out in the country so its a 30 min drive to get any pools supplies. I am trying to do this with as few trips and least amount of money as possible. Do I need to start vacuuming and if so, do I set it to waste or vacuum through the filter and then continue to backwash.
I have just read up on the SLAM technique and not sure if I have messed up and its too late to start this or where I should go from here...Any help is appreciated!
Matt
Matt
