Results 1 to 17 of 17
Thread: Can I slam every week to prevent algae ever returning
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Hi. Had my 1st appearance of green algae. I thought it was from pollen as robot vacuumed it easily.
    Here were my readings on 4/25 when I began noticing it:
    FC 4
    TC 4.5
    TA 60
    CH 225
    CYA 50
    PH 7.5
    I had been using pucks but have now stopped.
    Slammed FC up to 24 and it has only dropped FC 1 and CC .5 overnight for several days.
    Pool good now. Thanks TFP for all the info on slamming.
    Now my question:
    As I stopped using the pucks, I'm buying liquid chlorine in 2.5 gal. reusable jugs weekly.
    Can I add the whole 2.5 gallons at one time without adverse affects.?
    According to the Chlorine/CYA chart this would bring FC up to about 24 initially and then over a week back down to a 6 to 9 target range.
    I wouldn't have to store the chlorine and this would be almost as easy as using pucks.
    And I'd wouldn't have to worry about algae again.
    Thanks
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Jan 2017
    Monterrey, NL, Mexico
    490
    Re: Can I slam every week to prevent algae ever returning
    I would just go for the SWG since you are already thinking about it. Yes you can drop the whole bucket, but TFP does not recommend that, too much of a swing and can cause damage to your equipment and plaster. If you cant get the SWG then opt for a stenner type pump for the chlorine!
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    JoyfulNoise's Avatar
    May 2015
    14,080
    We do not recommend having chlorine levels that high all the time. It's basically wasting money as most of the chlorine is just getting burned off by the UV. Over time you are putting greater chemical stress on your equipment because FC is still FC - the CYA moderates the reaction rates but chlorine is still "attacking" everything in the pool. So, by overdosing the pool, you are basically exposing everything to a higher level of chlorine all the time. You can think of it like this analogy - going out in the sun can be a good a thing (Vitamin D) as long as you are moderated in your exposure; going out completely bare in the sun with no sun block on for hours on end will also create lots of Vitamin D as well cause advanced skin aging and skin cancer.
    As the Greek Philosopher's taught -
    Παν μέτρον άριστον, μηδὲν ἄγαν. (Pan metron ariston, meden agan.)
    "Everything in moderation, nothing in excess."
    Matt
    Jan 2017
    490
    Greek Philosophers did not have Beer! Does not apply!
    Felipe
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,493
    I'll bet you have a good reason for what you want to do, so while I agree entirely with dosing (SWG or Stenner) to reduce the daily tasks, it might be an option for you to try adding FC every two days, then every three days, then twice a week, and see how it goes.
    Not to mention the added stress on finishes and swimsuits, you'll find with weekly dosing that you lose most of the chlorine in the first two days, and then you won't have enough residual to last the rest of the week. Throw in a swim day or especially hot sunny weather, and it's almost assured your FC will fall below the minimum.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Quote Originally Posted by needsajet View Post
    Thanks everyone for all the replies. At first it seemed like a good idea.
    Needsajet: What I didn't consider is the loss of FC at a more rapid pace at the higher levels.
    If I'm losing 2 ppm per day at lower FC chlorine levels will this increase to 3 ppm or 4 or more a day at higher levels?
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    You don't need to SLAM every week anyway if your chlorine level is kept where it needs to be. Algae, most harmful bacteria, and viruses can't grow in a properly maintained pool. Just make sure you test often, and add chlorine when necessary.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    needsajet's Avatar
    Jan 2016
    4,493
    It will depend on how much sun you get on the water, and how much swimming. It won't hurt to try it once and learn. Your screen would make a big difference I bet, but you still have to think about the downside of frequent high FC levels.
    In my experience, yes, 5 ppm drop in full sun from a high level. I'm using post-SLAM experience, with a pool in full sun and daily or every other day use. My pool will drop from 28 to 12 ppm FC in 3 or 4 days. This would vary a lot from pool to pool.
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    I'll be doing a lot of testing and try to arrive at the proper amount of Chlorine to add every few days or more.
    Also I have to compare this to how much the 2.5 gal jugs deteriorate sitting outside or in the garage. I have 2 of these. Used one and transferred the other to 1 gallon jugs and have them in the house.
    needsajet's Avatar
    Jan 2016
    4,493
    You won't huge difference in the chlorinating liquid unless it's left in the sun or wasn't fresh to begin with. A couple months doesn't affect it very much indoors unless the temperature is high. I'll bet you get to an easy routine.
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Did the OCLT this a.m. FC dropped 1 ppm and CC was 1 ppm. FC 24 CC 1
    Tested FC this evening and loss was 3 ppm for the day. FC 21 CC 1
    needsajet's Avatar
    Jan 2016
    4,493
    That seems pretty good so I'm guessing your screen is keeping a fair bit of sun off the pool.
    I wonder why you're getting CC at 1 ppm. Do you see that much CC when the chlorine is at your normal level?
    Killer95Stang's Avatar
    Sunny SoCal
    695
    Just bite bullet and get a stenner or swg system. I hope I'm not in the minority when I say I've never had algae. This is the start of my 4th season and i've never dealt with a slam, so to me its not normal.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Tested FC again this evening and loss was 3 ppm for a full 24 hrs. FC 18 CC 1 (Yesterday's reading was 3 ppm plus the 1 ppm from the OCLT = 4 ppm)
    Pool temp is now 78. Full sun but very filtered through the fine mesh super screen.
    Yes my CC readings were .5 before the high level of chlorine. It might be because of the time it takes to do the FC test. When I do the CC test the first 1 drop does makes it clear but a few seconds later on close examination there is a hint of pink and I add another drop.
    Will see how my readings are as I get down to lower FC levels each day. I'm hoping for 2 ppm loss per day and .5 CC
    May 2015
    14,080
    No, that's not right. If one drop turned it clear than it is 0.5ppm not 1ppm. The CC portion of the test suffers from color break through - if you leave the clear sample there long enough, the DPD re oxidizes to pink. This is why the test should be performed in under a minute. You do the FC test get it to clear (the clear is stable) then do the CC test. Once the CC part of the test goes clear, you stop and ignore any other color changes.
    Matt
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Thanks for the clarification. Then my CC is .5
    Quote Originally Posted by Killer95Stang View Post
    Still evaluating. I'll probably get a SWG eventually. 1st season was pucks. This season is liquid chlorine. I'll make my decision for the 3rd season.
    What I hope never to see again is Algae.
    BTW, I'm getting the chlorine for $3.89 in 2.5 gal jugs at Ace Hardware.
    needsajet's Avatar
    Jan 2016
    4,493
    Good price!!!
    Glad to hear the CC is 0.5 or less. Sounds like your pool and your TFPC are spot on.
