Results 1 to 7 of 7
Thread: aqua rite digital read out is blank
    Jun 2015
    Cary IL
    4
    I have a aqua rite chlorine generator. I wanted to check my salt level after I opened the pool this week. I turned the system off and then back on to recalibrate the system. When I turned it back on the digital readout started to blank out. I tried again reset the system. On the 3rd try all the lights came on for approx 10 sec, and then went out. I turned the system off and now the power light and the generating light stay on with the system off. Also the digital read out is still blank. Is my circuit board bad? I would order a new one but want to see if anyone else has had this problem before I spend $200
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,111
    Re: aqua rite digital read out is blank
    It could just be the contact between the boards. Turn it off, then pull the front display board off and carefully reseat it. It's not uncommon for it to resolve the issue.
    chiefwej
    16x36 rectangular (19k) Pebble Tec play pool/spa, Pentair Intelliflo VS 011018, Super II 2hp (spa), Aqua Rite T-15 SWG, Pro Grid 60 DE, H400 & Heliocol Solar, Dolphin S-300, fill water w/high CH and TA, 50 ppm borates,TF-100 test kit, Smart Home/Alexa pool control
    Jun 2015
    Cary IL
    4
    Thanks I will give it a try
    Jun 2015
    Cary IL
    4
    Thanks Chiefwej!
    it worked that was the problem
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    164
    This is a timely post for me as I am having a similar issue with the display, and also giving wrong information (showing I have a different cell, skipping the salt reading and temperature, etc.) My unit is 3 years old...just curious how old yours is lefevr1? Any one have any idea how often these units have to be replaced? I will try this fix tomorrow. Thanks!
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    May 2009
    St. Louis, MO
    45
    I, too, have this same issue. I see a new display on Amazon, GLX-PCB-DSP, for $84. However, I'll try re-seating the existing one first. It's raining cats and dogs here, may be a few days.
    30,000 galllon, inground, vinyl liner, L-shaped pool
    1.5 hp pump, sand filter, heater, run pump 24/7
    Aquarite salt system
    St. Louis, MO, USA
    Jul 2014
    Hickory, NC
    164
    Quote Originally Posted by chiefwej View Post
    I tried this today and it did not work for me. I did notice my GFCI test/reset button was not working. I plan to get this replaced, but in the meantime could this be a cause for the display messing up?
    ~ TF-100 test kit
