I normally maintain my pool with liquid chlorine and muriatic acid. I keep my FC level at the desired percentage of CYA, using the TFP guidelines. Have had no algae problems since I began using this method.
I have an in-line chlorinator that uses 3" tri-chlor tabs, but I only use it for a few weeks at a time, if I am away and cannot tend to the pool. Last September, after using tabs for a few weeks during my absence, I measured the CYA at 65. Since that time, I have only used liquid chlorine. Today, I measured the CYA at 45. I do not backwash the pool, since I have a cartridge filter.
Is it possible for CYA to go down that much in 7 months if the only way that water leaves the pool is by evaporation? Allowing for measurement errors, it could have been 60 last September and 50 today, but that is still a noticeable drop. I'm not complaining, because I may have to use tabs again for 3 weeks when I go on vacation soon. Just wondering what can cause CYA to drop, since I see people on this website saying that it can only go down when some of the water is removed by backwashing or draining, not by evaporation.
