Thread: First time on my own
    Ready2swim's Avatar
    Jan 2017
    Hallsville, Texas
    13
    So the pool has officially been turned over to us. I will get on the computer and update my signature with equipment but first I need reassurance that I am doing the right thing.
    My numbers are
    PH - 7.8
    FC- 2.5-3
    Total Alkalinity - 120
    Calcium Hardness - 200
    cYA - 80
    My pool is approximately 26200 gallons so it looks from pool math that I need to add 30 oz of muriatic acid, 54oz of 6% bleach, and a whopping 582 oz of calcium chloride??? I am attaching my pool math results and I picked up some muriatic acid but now I'm not sure it is the right kind....and where do I get calcium chloride.
    To say I am overwhelmed would be a huge understanding, haha!!
    16 X 38 Roman shaped plaster pool (3.5' in shallow end, 8' in deep end), tanning ledge with lighted bubbler, Pentair WhisperFlo 2HP pump, Pentair 100D Sand Filter, Pentair intellichlor Salt Generator, Pentair Glo-Brite Light, Pentair Color LED Bubbler, Pentair Kreepy Krauly Prowler 820
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    Re: First time on my own
    You're not on your own. You have us.
    I wouldn't worry about CH unless you have to get some kind of documented test results for warranty. It'll climb plenty quick as it cures and through evaporation. You set the target on poolmath. Why'd you go to the high end of recommended?
    If CYA is really 80, you need to target a higher FC.
    That "green" acid is not full strength stuff. Of course there's less fumes --- there's less acid! You need to find out the concentration and use the right one to calculate the acid dose.
    It would be a big help if you'd fill out your signature and also tell us where Hallsville is. I had to look through your post history to see that it's a plaster pool. Later on, when you have more posts, nobody's going to bother.
    dirtworm_ato's Avatar
    Dec 2016
    Little Rock, AR
    40
    Hi! Welcome to TFP! I'm still new myself, so I'll let the experts chime in to validate your numbers. As a new, first time pool owner myself, I'll just say that this forum has been fantastic for me to learn how to take care of my pool. We've had water in our pool for just over a month now and the water has stayed crystal clear following the recommendations here.
    One thing I did want to warn you of is that the pic of the muriatic acid you posted is the lower concentration stuff. I got caught off guard by this too, but the stuff that says "low fumes" I believe is half as concentrated as the 31.45% stuff, so adjust accordingly. The full strength stuff should say on the bottle the concentration level. If it doesn't, assume it is half as strong.
    Good luck with your pool!
    Little Rock, AR - 25,000 Gallons Free-form Gunite (2017)
    Pentaire Intelliflo 2 3hp VSP & Intelliflo Whisperflo 3/4hp pump for water features
    Mastertemp 400K heater
    Clean and Clear Plus 420 sq ft cartridge filter
    Intellichlor IC40 & Intellitouch Controls
    Ready2swim's Avatar
    Jan 2017
    Hallsville, Texas
    13
    Thank you so much! I have updated my signature, I have to get on an actual computer to do that so I had not done it yet
    Where would I find what my FC target needs to be? I intended to use default goals but looking back at it, it appears I messed up on some data entry. I will definitely pay more attention to the acid when I purchase it from now on.
    Thank you for your help!!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Most bleach off the counter today we recommend is 8.25%. You don't mention salt level for SWG. I know where Hallsville is! I can spit and hit it!
