Results 1 to 17 of 17
Thread: Opening pool -CYA questions
    Apr 2017
    NJ
    24
    Question Opening pool -CYA questions
    Ok Im a tad confused. I was here all last year but had to sign under a new email. Anyway I have a Vinyl 20 x 40 SWG with a 6 foot deep end. Last year I had a battle with algae and I followed all the SLAM directions and everything was great. I don't think my CYA was as high as it should have been with a SWG but with the help of everyone on here we decided to keep it where it was to help me SLAM the pool. I was supposed to then raise the CYA(I remember it wasn't awful maybe 40 or 50?) but then had to fight algae again. It took a bit to beat it but by then the season was over.
    So now.. I just opened my pool. It is green with lots of green clumps floating. It actually doesn't look as green as it has in the past. But I did the numbers . My PH is 6.8 . My TA is 30. Of course chlorine is 0. When I do the CYA , I get all the way to the top and its crystal clear. So I get confused, does that mean my CYA is over 100? Or non existent? How did it go the other way? What is my course of action beside vacuuming and shocking. I have my big tanks of liquid bleach ready. My pool is pretty filled from all the rain.. so we are vacuuming an backwashing.
    I just want to make sure I am doing this right. I should shock it and then fix the TA and PH when I clear it?
    Plus it smells really bad.. It hasn't ever smelled like this.. but I have never had the floating green bushy looking things( that is the technical term) . I usually just have algae all over the bottoms , sides, leaves and worms.
    Donldson's Avatar
    NW Ohio
    3,217
    Re: Opening pool -CYA questions
    Welcome back to TFP!
    No cloudiness means no CYA. Can you describe the smell? Does it smell ammonia-y by chance? And can you post a picture of one of the clumps?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Apr 2017
    NJ
    24
    hmm as I further investigate( I think) , Im thinking my CYA is non existent... which might be a better thing than having it high. So it should make it easier for me to SLAM it?
    Apr 2017
    NJ
    24
    Ok. I will take a pic. No it doesn't smell like ammonia.. maybe rotten eggy?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,728
    Hi, welcome back! Our administrator can help you merge these two accounts. Just send a notification with your request to Leebo and he can help you.
    As to your current problem, a clear CYA tube means there is 0 CYA in the pool. You have likely experienced a rare event where the CYA is consumed over the winter. This leaves some byproducts in your pool that will have to be dealt with as part of your pool cleanup. You will need to do a slam, but for the first few hours you will need to test FC and add bleach approximately every 15 minutes until the rapid loss of FC slows down. When you are able to hold chlorine loss to less than 80% 15 minutes after a chlorine addition you may follow normal slam procedures.
    A slam will temporarily raise your pH, so I would check it during the slam and if it is still below 7.0 we can look at raising it a little. Otherwise don't adjust anything else until after the slam is complete. You will need to add some CYA but wait until after the chlorine holds more than 15 minutes.
    Love TFP? Become a
    TFP Supporter!
    Apr 2017
    NJ
    24
    20170428_191233.jpg It
    It actually might be grass clumps now that I got a better look at it since vacuuming. It kind of smells like fish..I don't know..lol
    Quote Originally Posted by zea3 View Post
    Ok will do! Thank you ! Ok well a clear CYA is better than a high CYA right? Use the pool calc to know how much to put in?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Just to be sure.... you took the sample you tested after the pump had been running awhile, yes? If you had a porous cover on it, rain and snowmelt got in and pushed out some pool water and sits as a layer on top. Make sure the water has mixed well before you trust the sample.
    Donldson's Avatar
    NW Ohio
    3,217
    Hmm, yeah looks like some organic matter got under the cover and is growing algae of its own.
    Not sure about the smell, but I would follow the procedures Zea mentioned before adding CYA. If you notice a big CC number come up then be very glad you are performing the procedure as it is saving you a lot of time
    After you complete the SLAM I imagine the smell will be gone, if not we can try attacking that separately but I imagine it will clear up with chlorine.
    Apr 2017
    NJ
    24
    It's one of those safety covers.. and yes I believe porous. No , I took it before the pump is running. So I should test it again. I should do the CC test? I hadn't done that one yet
    Donldson's Avatar
    NW Ohio
    3,217
    You won't have any CC until after you add some chlorine and give it time to circulate (if you have CC at all), but Richard saw what both I and Zea missed, yes you need to get the water circulating before running your tests.
    Richard320's Avatar
    Jan 2010
    20,299
    Quote Originally Posted by Jennels View Post
    Yes, test again after the pump has been running a while. Maybe start brushing to further mix things. Drag anything you can catch with the skimmer out, too.
    Apr 2017
    NJ
    24
    Ok..will do.. I should not add chlorine yet then? My husband is vacuuming out the bottom and then will run it? For the near future.. if my CYA is still that low, I get a little confused on where I am supposed to keep my shock levels at. I thought it said 10 but that seems low?
    Richard320's Avatar
    Jan 2010
    20,299
    Don't add chlorine until you're certain of the pH and CYA values, and that will be after the water has been thoroughly mixed. If the pump's been on and someone has been brushing and vacuuming, half an hour should be plenty.
    The pH test will be off during the SLAM so you can't test it during, so you need to get it right before you start bleaching. So retest before dumping in bleach.
    Shock level depends upon CYA level. If you have no CYA, then 10FC is plenty. As CYA goes up, so does shock level. Pool School - Chlorine / CYA Chart
    Apr 2017
    NJ
    24
    Thank you. It's been a whole year so I forgot. I need to go reread.. We definitely stirred it up and the pump has been on about 20 minutes. Will test soon and start adding chlorine.Thank you!
    Apr 2017
    NJ
    24
    Ok.. so you guys are awesome as always. I just retested and my ph seems to be now 7.4. My CYA is still nothing. We started chlorine
    Donldson's Avatar
    NW Ohio
    3,217
    Let us know what your FC and CC numbers are when you test at the 15 minute mark.
    Richard320's Avatar
    Jan 2010
    20,299
