I have cloudy water and am not seeing it clear up - I believe my numbers are in the proper ranges after reading pool school info and have also deep cleaned the sand filter prior to opening. Filter is in good operation - no leaks or broken parts noted. I am unable to pass overnight loss test due to cloudy water. See water results below. And feedback is appreciated - thanks in advance!
My only next steps I think are:
1 - raise ph to 7.4-7.5 ( prob not necessary)
2 - add de to sand filter (not sure this will eliminate the cloudy water
Setup
24 ft round vinyl ag pool - (about 13500 gallons)
hayward sand filter and matrix powerflo pump
using 8.25 bleach for chlorine
4/23 test results
ph - 7.2-7.3
fc - 21.5
cya - 50-60
ch - 150
Al - 70
results from today - note no chemicals added since last test and we did receive some rain
ph - 7.2-7.3
fc - 20
cc - .5-1
cya - 50-60
ch - 125
al -70
Setup
4/23 test results
ph - 7.2-7.3
fc - 21.5
cya - 50-60
ch - 150
Al - 70
ph - 7.2-7.3
fc - 20
cc - .5-1
cya - 50-60
ch - 125
al -70
