Thread: Test results question - TA
    Jul 2013
    Long Island, NY
    554
    Here are my results. I still have my winter cover on. Added chemicals last week. What is the recommended levels for TA. In pool school it doesnt list the levels, just what happens with high & low levels. Is 60 ok? Should I raise or lower this? Thanks
    FC - 9.5
    CC - 0
    PH 7.5 (I think)
    CYA - 60
    TA - 60
    Salt - not yet added
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Re: Test results question - TA
    As long as the pH is good, I would leave TA alone.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Jul 2013
    Long Island, NY
    554
    oops. haha thanks! - poolDV
    Yeah I think PH is good. Just a bit hard to tell, though it definitely was NOT the highest or lowest value on the chart. I did use the white sheet of paper trick. I would think the PH would be fine. Filled the pool 2 weeks ago. Thanks James
    SWG: Intex CS8110
