Results 1 to 13 of 13
Thread: Turned on SWG today and getting errors
    So the water temp is 63 so i decided to turn on the SWG. I have the aquatrol with T cell. Salt level taken with tftest kit is 3400. Diagnostics from awuatrol are as follows
    Salt 1300
    Temp 63
    Voltage 31
    CC 0
    Output 30%
    ISAL 0
    Thanks for any help
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Re: Turned on SWG today and getting errors
    Try this:
    Move switch to off
    turn dial to 50%
    Move switch to auto
    Recheck diagnostic readings
    Support the site
    Same results but showing 50% output
    It does read 2000 for the salt now without adding any.
    You should get an instant salinity reading as soon as you hear the click of the unit turning on. As soon as you hear the click, go to instant salinity and watch that number until it stabilizes. Then, move the switch from auto to superchlorinate and back to auto.
    Support the site
    I dont hear the initial click but moved it to superchlorinate than back to auto and get this. The bottom 2 lights are now blinking
    Update. Inspect cell went off and now only check salt is blinking
    Recheck all diagnostics.
    Support the site
    Salt 2700
    Temp 62
    Voltage 26.6
    CC 2.68
    Output 30% moved back ti 30
    ISAL -2600
    Ok, it looks like your salinity is about 2600. You should get it up to about 3200.
    I would turn off the SWG, add salt and then turn the SWG back on when the salt is thoroughly mixed in.
    Note: What you're listing as "CC" is actually amps.
    Support the site
    Just realizes the amps part. Sorry about that
    So should i ignore the salt test with the tf kit? I added 17 drops before it went brick red so i figured i was at 3400. Ill pick up salt whule at work in the morning and report back in a couple of days
    Thanks james!
    Salinity is never exact. Your actual salinity might be about 1/2 way between both readings.
    If the cell is old, it might be beginning to wear out. If the cell is wearing out, it will underperform and the system will underestimate the actual salinity.
    You can make the cell work longer, but you have to keep increasing the salinity. Eventually, it will be best to replace the cell.
    I would use the cell until it reads 1000 ppm lower salinity than actual.
    Check the cell for scale and acid wash if necessary (but only if needed).
    Support the site
    Will do. Only one season under its belt but ill check it again. Have to get kiddos ready for night tine and school tomorrow. Thanks so much
    So i added the 1 bag yesterday and it went up to 2900 reading on the panel. Need to check the math because i forget how much 1 40 lbs bag should raise it
