Thread: Hot Start or Follow Wet Edge Guide??
    TxBwana's Avatar
    Mar 2017
    Plano, TX
    73
    Question Hot Start or Follow Wet Edge Guide??
    Well, the Wet Edge plasterer just left. He said to do a hot start and recommended adding 4 bottles of MA for my ~15,000 gallon pool/spa.
    I am the one responsible for start up.
    This contradicts what Wet Edge specifies. http://www.wetedgetechnologies.com/f...structions.pdf
    Which should I do?
    I want my Wet Edge warranty to be valid.... plasterer added sequestrant. Going to start brushing as soon as they can fix the switch today and get me power to my aqualink so I can start my pump.
    What do you guys think?
    Oh, as per my sig, I've got Wet Edge Prism Matrix in Constellation.
    Going out to test the water with my TF100 kit now.
    15k IG gunite, built 1999, RiverBend Sandler, attached spa, Dolphin S200, Pentair Triton II sand filter, Wet Edge Prism Matrix in Constellation with extra ocean shells handcast, Pentair MasterTemp 400, my remodel
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Hot Start or Follow Wet Edge Guide??
    Not a fan of hot starts at all. I would follow that guide before I did a hot start. I don't know how involved you want to get, or what your makeup Chemistry is, but there is a bicarb startup option. Sorry you didnt get answered yet, hopefully you check in soon and let us know.
    Essential Links:
    TxBwana's Avatar
    Mar 2017
    Plano, TX
    73
    Thanks, we live in an area that has slightly alkaline water. When I tested it after filling, it had a calcium hardness of 225, ph of 8.2, total alkalinity of about 100. After reading a bit more about hot starts I decided to do exactly as Wet Edge tells you to since they are who is giving the warranty. So I brushed twice today and adjusted the PH downward. Will check in the morning to see how much MA to add. I think hot starts are for people who don't want to do the brushing and test twice daily, etc. I would rather do that than degrade my finish by dumping a ton of acid in my pool. It's no big deal to me to brush the pool and test. Seems like Wet Edge wants you to follow the Traditional Start Up.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Exactly. Sounds like you've done plenty of reading and took the right track. Good for you.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Good call to follow Wet Edge guidelines. I'm also not a fan of a hot start. Congrats on the new pool!
    TxBwana's Avatar
    Mar 2017
    Plano, TX
    73
    Thanks, Patrick!
    PoolDV, I didn't like what I read about hot starts... and I'm so glad that I decided to go with the Traditional Start that Wet Edge says to do. The pool is already looking good, not that much plaster dust, color is bluer every day, and the water is really clear. Plus, it hasn't been that hard to keep the Ph level correct. I read where a hot start can make you have problems with the ph rising for a year or more because the acid softens the plaster.
    Pool isn't new, but it feels like it is with the new finish. I would have never picked a white finish like the people who built it, and would have made it deeper to keep the water coolor here in Texas. But it was already here and it was a lot cheaper to buy a house with a pool than put one in.
