Thread: Pool light - output (comparing SAM to IntelliBrite 5G)
    Jan 2017
    Orlando/FL
    124
    I'm looking for information regarding how much light output (lumens, candlepower/candela, foot-Lambert, whatever) for the (Pentair) SAM Spectrum Amerilite (color changing) and the Pentair IntelliBrite 5G (color changing) pool lights.
    For comparison, it would be helpful to know what the light output is for both types (for "white" light).
    I want to know if they are close to the same "output".
    I currently have two SAM lights in my pool (both are not working now). I can buy a repair kit for the SAM or for a little more money, get an IntelliBrite.
    All of the manuals/brochures I have found for these lights just talk about power (watts) consumption. No mention of light output.
    Some reviewers on the IntelliBrite say they are not as bright as expected/desired. I would not want to buy these these and then find out they are significantly dimmer than my current lights.
    It's odd that they don't tell you this. All of my landscape lighting sources always provide the light output and light spread charts for the various fixtures they sell.
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
    mas985's Avatar
    Pleasanton, CA
    11,983
    Re: Pool light - output (comparing SAM to IntelliBrite 5G)
    I have had both lights, and the 5G is maybe a little bit darker especially for the color red but not enough to be an issue for me. I would much rather have the energy savings and the reliability (hopefully) than the brightness.
    Have you looked at any of these videos. They are pretty realistic to what I see.
    Intellibrite 5G video - Google Search
    Mark
    Jan 2017
    Orlando/FL
    124
    That was very helpful. Thanks.
