Thread: Need pump advice
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    120
    Need pump advice
    SO did a lot of reading
    But not sure what direction to go
    Specs are in sig
    Filter is a 300lb filter with 150 lbs of zeobest
    My 2HP 2 Speed Dynamo pump quit working on high last year
    Im looking at these 2 pumps
    1Hp Hayward SP15922S or the 1.5 Hp Hayward SP15932S
    Or any other suggestions would be appreciated
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Need pump advice
    1 HP is plenty big for your pool. I would look at the SP15922S. Two-speed would allow you to save even more money when you run on low, which is what I would run at when you have the pump on for generating chlorine. Should only need to run on high for extra skimming or when vacuuming.
    Isolated Spa - 345 Gallons
