I just realized I did something incredibly stupid and I need help.
My pool is 33k gallon vinyl w/ SWG and sand filter. Test results before the mistake were:
FC: 6
CC: 0
Ph: 7.4
TA: 70
CYA: 70
Salt: 3200
Borates: 15
I used Pool Math with the intention of calculating requirements for bringing my borates to 50. I mistakenly left the pull-down menu on borax when my plan was to use boric acid. So, here's what was added today: 1356oz Boric Acid and 646oz Muriatic Acid. What SHOULD have been added was just 879oz of Boric Acid and no Muriatic Acid.
I haven't tested, but after realizing my mistake I used the "effects calculator" at the bottom of pool math to see what my error likely did to my water. My borates should be 69, my pH 2.37, and my TA zero.
I could really use the advice/recommendations of some of the heavy-hitters here to help me recover asap to keep potential damage to a minimum. I'll followup in the morning with updated test results, but am not sure how to estimate pH given anything below 7 is out of range on my kit.
FC: 6
CC: 0
Ph: 7.4
TA: 70
CYA: 70
Salt: 3200
Borates: 15
