I'm just getting close to opening the pool for the first time - and along with that figuring out a starting point for water chemistry. It was installed / filled last fall, hooked up the autocover, and then we closed it up. The weather is getting warmer up north, so I'm trying to complete my plan for how I start. I've been doing reading - I thought I had everything figured out after going through Pool School multiple times and using Pool Math. Then I went back and started reading about others' experiences with similar equipment setups. Adam T's DIY Pool Automation document is nearly identical to what I have for equipment.
I know that the recommended range for CYA on a SWG pool is between 70-80, however I've also read that with the Intellichem, that if your CYA is over 20, then the ORP doesn't function correctly. Since CYA and FC are directly related, I know that I need to figure out where I want to start for CYA before I can really gauge what my FC should be.
So for those that use the Pentair Intellichem (with a SWG and automatic dosing of MA), what should I target for my CYA?
Our pool has an autocover, and will be covered 99% of the time (with the exceptions being weekday evenings when the kids want to swim, and weekend days when they're in the water). I'm anal about both safety and cleanliness, so it'll be closed if we're not by the pool.
