I am converting over to the BBB method as I am using up existing chemicals. I have used the Pool Calculator and it is amazing.
I have three questions:
If beach is needed in the pool to prepare for a heavy load of swimmers, how long after it is put in, can the kids into the pool?
I am interested in using my fountain to aerate my water - I think I read that is good for ph? Regardless, it helps keep the birds away from the pool ) Will my fountain be sufficient for this over some of the aerators I have read about on the forum? Would it be best to have the water shoot up as a fountain, or bring it down to the water level to move the water around?
Finally, the CYA test that this forum recommends - is it better than what my local pool supply store uses? (they use a computerized test called PINPOINT)
Thanks for the help!
