Results 1 to 8 of 8
Thread: Skimmer placement?
    Mar 2014
    Tampa
    107
    Skimmer placement?
    Not happy with skimmer cut into the coping. On my last pool it was not cut into the coping but right behind it. Can these be extended? PB said That's how they go. The front of the skimmer has to reach the tile. Or at least come close.
    Aug 2014
    Houston tx
    2,542
    Re: Skimmer placement?
    Mine are probably a foot behind the coping.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,149
    This is not the normal installation in gunite. The skimmer mouth is usually met by tile that goes under the coping by about 6", general at a small angle. So the skimmer cover resides about a inch or several behind 12" coping.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2014
    Tampa
    107
    Agreed I reached out to PB. I want it past the coping. I hope they can accommodate my request. Since I am doing travertine deck, I also want a square lid cover to blend in with French pattern...thank you for your input!
    Mar 2017
    North Texas
    43
    Question: Is that a normal 8"x16" travertine coping stone? That's what they look like. With the placement of the coping I think you are looking at 18" minimum setback on the skimmer ring to keep it from cutting the travertine. Not sure if that distance is possible or not.
    Mar 2014
    Tampa
    107
    They are 6 X 12 coping . I would like it just passed the 12"and i am getting push back. The skimmer mouth is to close to the wall tile maybe an Inchon. not set back a few more inches.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,149
    Just a case of a PB who is set in their ways. He does it that way so everyone else does too and it's the standard! Except that it's not.
    Mar 2017
    North Texas
    43
    Quote Originally Posted by Agd38 View Post
    In that case I would have it moved. Looking at mine last night I think it was 16 inches from the wall.
