Results 1 to 9 of 9
Thread: Jet direction
    Jun 2015
    St. Francisville
    78
    Jet direction
    Searched the forum but looking for for specific advice for my setup. I have 4 jets on a rectangular pool. One at the steps (just inside the steps pointed towards the shallow end wall and away from the return). One at the other side of the shallow end (opposite the steps) and pointed in the other direction towards the deep end). One on the far deep end of the "long" wall just past the ladder and pointed to the opposite "long" wall on other side of deep end. One on the deep end "short" wall and pointed down the other long wall towards the shallow end. The skimmer/return is halfway between the first (stairs) jet and the last (deep end) jet.
    Should I point them all down? Or point them at and angle to circulate clockwise? Or a combination of the two?
    30k gal, IG, vinyl, Pentair Tagelus TA 60D sand
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Jet direction
    You want clockwise or counterclockwise circulation. Try both to see which one works best.
    Jun 2015
    St. Francisville
    78
    Re: Jet direction
    I see some things about pointing one downward or all semi downward. Anything to this?
    DFW, TX
    24,974
    Re: Jet direction
    No, mine all point counterclockwise to support flow.
    Jun 2015
    St. Francisville
    78
    Re: Jet direction
    Quote Originally Posted by pooldv View Post
    Apparently the school of thought is one or more pointed down or in a somewhat downward direction keeps stagnant water off areas of the bottom. Otherwise only the top surface water gets filtered.
    30,946
    Re: Jet direction
    Apparently the school of thought is one or more pointed down or in a somewhat downward direction keeps stagnant water off areas of the bottom. Otherwise on the top surface water gets filtered.
    That is not the school of thought at TFP. pooldv's suggestion is what we teach and has been well thought out over the years.
    You can certainly set your return eyeballs for what works best for you. All pools are different and you may decide you like a different eyeball pattern.
    Jun 2015
    St. Francisville
    78
    Re: Jet direction
    Ok thanks. I'll go with that everyone recommends was just hoping to get some "physics" behind the reasoning. So what about the jet inside the steps? Point towards the top step to push water around step or point out away from steps to keep water from entering this "dead zone"? Or just straight ahead towards shallow end wall?
    DFW, TX
    24,974
    Re: Jet direction
    Ha, yeah sorry, not a physicist. I just point my eyeballs various ways until the pool surface stays clean and report back.
    I would point the stair eyeball so that continues the flow started by the other eyeballs. And try both ways. I started clockwise because it seemed the most logical based on where eyeballs were in relation to the skimmers but counterclockwise ended up being better. And speaking of dead zones I did have a dead zone in the shallow end while it was clockwise where debris gathered on the bottom and switching to counterclockwise solved that.
    Oct 2016
    Phoenix
    203
    Re: Jet direction
    I removed all my return outlet eyeballs long ago and let the water flow out as it may. I have a smaller pool so maybe I can get away with that where others might not. I never have any issues with algae-prone dead zones including steps and a swim-out that are not close to any returns. My vacuum-side pool cleaner drives around each day acting like a center drain on wheels. The actual in-floor drain was blocked off so I get high skimmer flow at low pump speeds. YMMV
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
