Thread: Rip froggy
    Nov 2015
    Ok ok
    851
    Rip froggy
    Went to cleaning one of my skimmer baskets, there was a large frog in the basket. I was simply going to pull out the basket and remove him with the leaves, but halfway out he jumped, and sure enough......down the suction he went. This is in the skimmer that I thought may have a leak because when I pull from it exclusively, it would pull a lot of air/cavitation. I went up to my pump basket, and after a while even with the pump running very hard no sign of him. The next day, there he was fully intact in the pump strainer basket..... at least I know my line is not plugged. Was happy to see him show up...... lesson learned, from now on when I see frogs and or snakes, they're coming out before the basket does!
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Rip froggy
    Ha, yeah, that could've been ugly! Ewww. I have dumped tons of frogs out of my skimmer baskets and never had one jump down the drain. I'll have to be more careful too.
    Re: Rip froggy
    Critter Skimmer
    Looks like there are several options for wildlife to self rescue...
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    Nov 2015
    Ok ok
    851
    Re: Rip froggy
    Quote Originally Posted by dtlight View Post
    Critter Skimmer
    Nov 2015
    Ok ok
    851
    Re: Rip froggy
    Critter Skimmer
    I did not notice the attached link earlier, that would make many frogs happy! Virtually every frog I find in my skimmer is alive and I let them go, what happened to me was kind of a freak deal, but it worked out I guess ....except for the frog
