Results 1 to 7 of 7
Thread: CYA and Chlorine
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    249
    CYA and Chlorine
    Hi. I'm looking for an answer on testing chlorine relative to CYA.
    Do the free chlorine tests compensate for the amount of CYA in the water? I understand there is a CYA/chlorine chart showing the required amount of chlorine at various CYA concentrations. However, most OTO test kits show an ideal chlorine range of around 1.5-2ppm. Why is this? If I run CYA at around 50 or 60, the ideal chlorine ppm would be off the chart if the OTO test doesn't compensate for CYA.
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder, Pentair Intelliflo VS Pump, Pentair TR100C Sand Filter, Stenner Econ E10T2A (chlorine), K-2006, Zodiac Baracuda G3 pool cleaner
    40,855
    Re: CYA and Chlorine
    There is no compensation in the tests. And that is why we recommend the FAS-DPD chlorine test as it can much more accurately test higher FC levels which are needed when CYA is in the water.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    948
    The manufacturers of testing equipment also don't generally factor in the FC/CYA ratio, which obviously requires higher levels of FC for the recommended CYA levels.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Donldson's Avatar
    NW Ohio
    3,212
    Quote Originally Posted by spoonman View Post
    You know what I say when someone tells me something is "off the chart?"
    "You need a better chart." FAS-DPD.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    domct203's Avatar
    Jun 2015
    CT
    3,892
    This is exactly why we recommend using a FAS/DPD chlorine test, and mention that the OTO is really only good for confirming the presence of chlorine, not the actual amount with any accuracy.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    249
    Guess it's time to get a FAS/DPD. Thanks for the help guys and gals.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    The pool industry in general doesn't recognize the FC/CYA relationship and that's why you see their FC recommendations of between 1 and 3.
    Even though the effectiveness of the method, (backed up by solid science) of keeping a pool completely free of pathogens as well as algae, has been known since 1973, they have no interest in promoting the FC/CYA ratio that TFP does.
    If they did recognize and promote it, then no one would need to buy all of the expensive chemicals which the pool stores and chemical makers sells.
    The Pool Industry consists of businesses which exist to make as much money as they can. Providing the pool owner products that work for the long term is not in their best interest. They need you to repeatedly purchase their expensive products so they can stay in business. Whether or not whatever they can sell you is what you really need doesn't seem to be of any consequence to them.
    It's pretty much as simple as that.
    Divin Dave,
