I finally purchased the taylor Chlorine FAS-DPD and tested my pool and typed in the results in the pool calculator. Here are my results.
PH 7.8
FC 1
CC .5
TA 70
CH 350
CYA 70
also used the Lamatte borate test kit and the result is 50 ppm.
I have no idea if its living in Phoenix AZ with this heat, but I can't keep my FC at a stable state losing 2ppm per day. I know my CYA is off but getting mixed info on emptying half my pool or getting a CYA reducer. Please help. It's getting expensive keeping the FC at normal levels.
P.S. lower the PH tonight to 7.6
PH 7.8
FC 1
CC .5
TA 70
CH 350
CYA 70
