Thread: Ph impact of Chlorine Sources
    Mar 2016
    Magnolia, Tx
    1
    How does the pH increase from 73% Cal-Hypo compare to that of liquid Chlorine (say 10%)?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Ph impact of Chlorine Sources
    Welcome to TFP!
    Toward the bottom of PoolMath there is a section called Effects of Adding Chems, you can select various chemicals and it will tell you what parameter it will change in the water.
