I have a pool I inherited with the house I bought - about 21120 gallons (16x32), in ground - It has a puck chlorinator (which I'm not using - just putting in the skimmer for now because I don't understand how to use it), a 30" (i beleive Hayward sand filter), what looks like a Hayward filter at the pump with a US Motors 1081 Pool Motor (C55CXKMB-5012) pump on it (probably replaced), a Hayward Booster Pump 6060 for the Polaris and a Polaris 280. Over the time from when I bought the house in Nov. until now, I've rebuilt the Polaris and have it running pretty good, some minor changes to make, but it's WAY better than when I first moved in.
I just started working on chemical checking yesterday - I'm only using the strips because it's all I have at the moment (open to test kit suggestions..) - and my chlorine was a little low at 3 on the strips and my ph was around 6.8 - so been working on getting ph up a bit. I've read some of the forums here on water chemistry, but not sure I'm following all or getting it right yet. At least the water is not green I guess
#1 - I can't tell if the pressure gauge on the sand filter is moving or not - I swear it isn't. I backwash 1x's a week (per previous owner) and rinse right behind that. I don't see the gauge move. I assume it's broken - don't know if that's something I can replace or not.
#2 - The skimmer is on the same side of the pool as the the return jets. there are 2 return jets - 1 at each end of the pool, same side as the skimmer. The skimmer is in the middle. There is little to nothing pulled into the skimmer. Bits and pieces, but for as much stuff as I skim everyday off the top of this pool, I'd think there would be more. I tried the ping pong ball over the weekend, there was a very slight breeze, but not much and that ball went everywhere but where the skimmer is. I tried re-adjusting the jets to no help. Higher in the water for more ripple and lower in the water for less ripple. IT just seems to push to opposite side of pool an debris hangs out under the ladder. Grr. lol. I'm very frustrated in this area.
#3 - there is silt at the shallow end of the pool a lot. It;s better now that I have the Polaris working better, but is that a sign the sand filter is not working right or something? Don't know the last time the sand was changed.
I'll start here with this and work from here.
Thanks for the help and input - just reading before registering has been VERY helpful with the Polaris for sure!!
