- Sep 15, 2008
- 145
- Plaster
- Pentair Intellichlor IC-40
A temperature issue just cropped up on my MasterTemp 400. It will heat up fine to the desired temperature ... usually 98-100 degrees; but as the spa cools down, the heater doesn't fire back up until the spa temp drops down to 94-95. Is there a way that I can keep the temperature range tighter?
Thanks!
Thanks!
