Results 1 to 18 of 18
Thread: Should I raise my Alkalinity?
    Jan 2017
    Charlotte, NC
    37
    It's a new pool and I have to add acid every day or every other day to lower the Ph. My alkalinity has now gone down to 50. My ph is currently 7.8, I added acid yesterday. Should I add baking soda and/or acid today? I'm not sure how to handle this since the baking soda will make my Ph go up. Also it's a SWG but we have been using bleach since it's too cold for the salt to generate chlorine. Do I still follow the SWG water level guidelines or do I follow the bleach?
    Pool completed December 2016, Pebble Tec, ~14k gallons, SWG, Jandy Pro-Series variable speed pump, cartridge filter, heater, iAqua Link
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Should I raise my Alkalinity?
    I would hold off on raising TA. Between that new plaster pool and your SWG you are going to be fighting pH for a while. FWIW baking soda is virtually pH neutral. Use the non-SWG numbers until you can use your SWG.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2017
    Charlotte, NC
    37
    Thank you. If the TA keeps dropping, at what number would you add baking soda?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    There isn't a magic number for that even though we do have a suggested TA range. Its dependant on other things such as CH, but don't assume you'll be needing to adjust. Your pH rise should be quite slow at that TA level, and you may have all the TA you need in your makeup water. Let it sit and see what it does pH wise. It might hover there and be ok, depending on what your other numbers are. Can you give us a full fresh set of numbers please? Also, BS will only elevate your pH a tiny little if it is fairly low, say 7.2 or less.
    Essential Links:
    Jan 2017
    Charlotte, NC
    37
    Ok I just did the TF test kit:
    FC 2.5
    CC 0
    CH 300
    TA 100 (i also re-did the test again using the kit from our builder that I used this morning, it was 60)
    CYA 60
    I retested the Ph with the little kit that came with the TF kit. It shows closer to 7.5
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Your FC is way too low for your CYA. That is more important than anything.
    But to address the TA discrepancy, the next time you do that test, wipe the R-009 bottle tip between drops and see if you get a smaller number.
    Jan 2017
    Charlotte, NC
    37
    Ok I've added bleach to go up to 5 and we will see from there. It's odd, I did wipe while using the TF kit since that's what directions said.
    Oh and my CYA is 60 because I originally raised it to 70 since I was following the SWG guidelines.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Not to belabor a point, but 5 is the absolute lowest you should get to with a CYA of 60 without your SWG running. Pool School - Chlorine / CYA Chart The target it 7-9.
    TA is fine tuning, don't worry about it until pH is acting really weird. With a fresh plaster pH is just going to go up for a while. You will be adding a lot of acid, especially when the SWG gets turned on.
    Jan 2017
    Charlotte, NC
    37
    I was adding 50oz to get to 5 so I figured I would start there and then re-test and bring it up more.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Always a good plan
    Jan 2017
    Charlotte, NC
    37
    I've added more bleach to get it up to 8. Since my level needs to be above 5, I can't use that yellow drop test. So do I use the powder test that's in the TF kit every day?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    If you have something going on you can...or every other day or two until you are able to predict what it will be with high accuracy. After a time you will have a feel for it, and wont need to test with that one daily. You will learn what your pool does in all weather and circumstances, so by that point a few times a week is usually more than enough for most pool owners.
    Essential Links:
    Jan 2017
    Charlotte, NC
    37
    I tested Alkalinty again today. Using the PB test, 60. Using TF test, 110. I don't get it.
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Quote Originally Posted by beachcozy View Post
    Trust the TF-100.
    What is this "PB Test"?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    What is the pb test? Strips?
    It kind of doesn't matter anyway. If you are trying to lower TA to reduce rising pH, there is one course of action to accomplish both, acid! TA is not that important unless it is very low or very high. I would recommend managing pH and only testing TA (with the Taylor drop test that came with your TF100 kit) once every couple of weeks or so and not worrying about it too much.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    The Taylor based drop tests included in the TF-100 is the most accurate pool test available, trust it. We do.
    Jan 2017
    Charlotte, NC
    37
    It's like the TF test, you add 2 drops of a clear and the 5 drops of green.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I would trust the Taylor based TF-100 kit rather than trust the kit from China. There's no telling what, if any standards they hold their reagents too, but those made by Taylor are held to very strict ones. You'll make yourself crazy trying to compare the differences.
    Essential Links:
