Hi everyone as the title says I'm having issues with my pool light tripping my gfci breaker. The pool light is attached to a gfci outlet in my pentair easytouch control panel. When I push the pool light button it trips the gfci breaker. When I reset the breaker and turn on the light again it works fine. Any idea what he issue could be when I first turn the light on? I also have a spa light that is filled with water but wired separately in the same control panel that doesn't have a bulb in it (when I can afford it I'll be replacing that next) if it makes any difference. Thanks for any help.
