Intex Pump Problem
Jan 19, 2017
1
Bryan, Tx
I own a 16' above ground intex pool with sand filter(Model SF60110). Well, a couple of days ago the pump stopped working and I noticed that the switch was stuck on the timer setting and would not switch to the off or constant on position. Does anyone know where I can purchase a new one(Switch Only).
Bypass the switch to be always on, and then plug the pump into an external outdoor timer. You'll have a lot more flexibility in setting your run time.
Replying to see if there are any other ideas/comments. My SF 60100 that is 2 year old now has the switch stuck in the timer position too.
I would rather not have to go all the way to the plug to turn it off.
Thanks for any info anyone might have.
-Eric
