New pool build. I am looking at using a 1 HP SuperFlo pump (due to good price) to run 2 bubblers + 2 waterfall bowls/scuppers. I'm having a hard time with the head loss calculation and determining if this is a good pump for this application. Flow rate will be: bubblers 5-10 GPM each, waterfall bowls 10-15 GPM each for a total of 30-50 GPM. The pump curve for 50 GPM is around 50 ft of water (see curve G below). There will be no filter and the plumbing run of each pipe will be under 60'. The bubblers and waterfall bowls will be on at the same time. I'm not sure what to expect for the head loss for the 2 bubblers. Also, the waterfall bowls are just PVC pipes coming up thru the middle. I'll have valves to turn down the flow for the waterfall bowls, so I expect there will be losses due to valves being partially closed. Looking for advice if this pump is a good option. Also, do I need to be concerned with too low a head loss and should I plan a plumbing path (not sure on the terminology) to prevent cavitation and dump water. The pump curve shows 85 GPM @ 20 ft of water.
