I'm converting from the pool store / BioGuard 1,2,3 program to the BBB program. I purchased the Taylor K-2006 test kit frequently recommended by Chem Geek. My current numbers are:
FC 3.8
CC .2
PH 7.3
TA 190
CH 350
CYA 80
Two questions...
First, I don't like my TA, CH & CYA numbers. Using the pool calculator, the CH & CYA numbers indicate to me I should be replacing water. I've been successful getting my TA lower via muratic acid and aeration to bring PH back up. Before I continue that program to lower TA, should I really be considering water replacement first to fix the CH & CYA?
Second, the store would check total dissolved solids. How important is that? Is TDS reflected anywhere in the results using the Taylor test kit?
Strom
IG 16 x 32 vinyl liner with slide
Hayward sand filter, pump, heater
FC 3.8
CC .2
PH 7.3
TA 190
CH 350
CYA 80
Two questions...
Strom
