Peter, That's the reason I thought of using that old Hayward 2 speed pump, because it has a low speed. Am I wrong there? I'm thinking if it's strong enough to run my spa I'm in. Also what does VF mean, variable flow? I was planning on running 2" pipes. Do your 2.5" pipes come down to 1 1/2" through the pool wall, and then through 1 " directional eye inlets? This is a curiosity I am running into. Do you run your VS all the time or part of the day?
Repairman
Yes, VF is variable flow. Pentair sells both types, with the VF being a higher cost. The difference is that the VF model somehow measures flowrate and adjusts the pump speed to maintain your flow setting as the backpressure builds up in the filter. I have the VS because it was ~$300 cheaper at the time. Don't know what the difference is now.
I really don't know if a 2-speed is strong enough to run a spa at low-speed because I don't have a spa. The multiple factors make it challenging to make that determination, as you're finding. Pump HP, pipe size, length of runs, even the number of elbow fittings will affect your ultimate flow rates. A VS/VF pump will let you dial in an optimum speed regardless of how all the factors add up.
Additionally, you could change that speed depending on your mood. A slow-to-moderate flow for just soaking or a very fast flow for massage jets.
Even without a spa, I use three different speeds. I have a low speed of around 1200 rpm for slow filtering most of the day. I run it up to ~2000 rpm for the pool vacuum for about an hour in the mornings. And in the late afternoon, I run it at about 2200 rpm for 45-60 minutes for skimming (we tend to get some afternoon winds as the temperature cools off around 4-5pm, so this cleans up most of the debris before it sinks to the bottom). The pump is ALWAYS running in VS mode since the top speed is ~3450 RPM.
And yes, the 2.5 inch pipes do taper down to standard inlet fittings, but there's still a benefit to having the larger pipe runs. I'm not familiar with the calculations, but here's a link that calculates volumetric flow rates versus pipe diameter (assuming constant linear velocity).
http://www.1728.org/flowrate.htm
Basically, with all else being equal, a 2.5" pipe will flow about 40-50% more water than a 2" pipe. This is primarily due to reduced boundary layer friction losses. I can't quantify how much it helps, but I'm quite certain it doesn't hurt.
