I am a new home owner and the home happens to have an in ground vinyl pool! I am attempting to close it myself from everything I have read on this site (which I really really appreciate) but have ran into an issue. The pool water level has been dropped below the skimmer and return lines. This meant dropping the water level about 2 feet (it is 4 ft and the shallow end and 8 ft at the deep end). I was able to successfully blow out and plug the return lines with a shop vac. However, I am having 0 success with blowing out the skimmer line, as well as am wondering if I need to do anything about the main drain.
So, here is how things are set up, although I don't understand all of it yet. There is a line connected to the skimmer that meets another line that I believe is attached to a drain at the bottom of the pool. They each have their own valve, and then combine into one line that heads back to the pump. I have attempted closing what I believe is the drain line and blowing air from both a shop vac and then a leaf blower from the pump to the skimmer, and then from the skimmer to the pump, and seen nothing happen. When I blow in at the skimmer, and pull the vac away, and I see the line fill back up part way immediately.
I will most likely go ahead and call someone in, as we are supposed to hit our first batch of freezing weather next week, but I figured I'd seek advice on here first. Thanks so much!
The first photo shows the pump and sand filter. I was blowing air to the skimmer by disconnecting the line to the pump and blowing air into that line.
Second shows the inside of the skimmer. I believe the second hole is a plugged drain hole? Is it possible this just isn't used at all? It was never unplugged. The third shows those valves that come up from under the ground that are attached to the skimmer and drain at the bottom of the pool. I believe the right valve is to the skimmer.
