Help Choosing "Air Pillow" to Close Above-Ground Pool
Oct 4, 2016
1
NY
I am performing my first "closing" of an above-ground pool in NY and am running out of time to purchase an air "pillow" to put underneath the cover. This above-ground pool is partially surrounded by a wood deck and it is 18'x33' in size. I've read suggestions of using an inner tube instead, since they are more durable and won't break after 1 season, but I'm not sure what size would be sufficient and how many I should use. Is there a better product? Would you recommend a standard pool air pillow instead?
I'm looking for advice on a product I should purchase as soon as possible since I need to close the pool in the next 2 days.
Thanks in advance!
