I thought i would share my TPFC evperience with you all.
We bought a foreclosed house in eastern Tennessee halfway between Knoxville and Chattanooga {beautiful area}. The had a 20x40 inground pool
that is 3ft. in the shallow end and 8ft. deep in the deep end.
The pool had not been used in at least 1 1/2 years. It had a cover on it but the liner was dropping in in a few areas and the pool was a pretty green with several big bull frogs living in it.
I had never messed with a pool before but my wife had a pool in her previous relationship-it was an above ground pool that they took down every fall.
Being new to this and having a liner that was dropping into the pool we contacted a local guy that does pools and he came out and looked at it and gave us two options, try to save current liner with no promise that it was not damaged or replace liner with a new one-we chose to go with a new liner install.
After liner installation and initially filling the pool we took water sample into a pool store and had it tested and they sold us some stuff to put in it.
After a couple of times going to the pool store I found this site and that is when I took over the testing and all.
When we started we started using the 3 inch tablets, when the CYA got up to around 60 we started using Bleach, let me tell you my wife was not very convinced that this was not going to ruin the new pool liner, she finally decided that I would not use something that would ruin the liner.
So for the first summer we did pretty good with the balance of the water we did have an algae outbreak in August but I was on top of it right away and slammed it.
Fast forward to this year, our water has been beautiful and sparkling all year, it really has been very easy to take care of our pool, we just dump a gallon of chlorine or bleach in every nite and I have only been testing once a week.
The current CYA is 40, I know that i should probably increase that and my chlorine usage would probably go down some.
I really want to either go SWG or stenner pump chlorine injection next spring.
So all in all I really had no idea that taking care of a pool was so easy and it does not take alot of time.
I will say that I think most first timers that come to this site do not know the CYA-Chlorine relationship and that most of them do not realize that you have to add chlorine or bleach everyday and when they realize this they think that it is alot of extra work compared to using the tabs where they just add to the chlorinating and not having to add anymore til maybe next week, truth is I spend maybe 2 minutes every evening after dark getting a gallon of bleach out of the pantry and taking it out and pouring it into the pool.
I am very thankful for the people that put this site together and that I just happened to stumble across it.
