I have one pool return that I cannot remove the eyeball seat. The outer ring and eyeball come out no problem, but the threaded pipe that connects into the wall which holds the eyeball will not move. I tried the plastic removal tool but the plastic part that fits into the notches simply deformed under the torque I applied to it.
So I have two questions.
1) Does anybody know of a way to get this thing out? I see there is a heavy duty removal tool made of metal, but it's a bit expensive.
2) Is it even necessary to remove the fitting? The only reason I want it out is so that I can install one of those threaded plugs when I winterize. If I leave the fitting in, I could use a rubber expansion plug right in the fitting, but is that water tight? I feel like water could still sneak in between the male threads of the fitting and the female threads in the wall. The water level will be above the return all winter.
Any help would be greatly appreciated!
Brian
Brian
