Thread: Does your filter dance?
    grumpy's Avatar
    Jan 2009
    Coastal South Carolina
    64
    My sand filter developed a leak and was recently replaced. This new one jerks and shudders a great deal. Much more vibration than I remember with the old one.
    I thought that the water flow through the filter and pipe should be pretty smooth.
    Am I seeing something normal? Does anyone have any suggestions on what to look for if there's a problem?
    12170 Gallon in ground San Juan Caesar's Palace fiberglass with integral Spa in a screened enclosure. 1 HP Pentair Whisperflow pump with Pentair Sand Dollar SD-80 sand filter. Intellichlor IC40 with EasyTouch wireless remote. Aquacal Heatwave Heat Pump. Taylor K-2006 and Aquachek Salt test strips.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Re: Does your filter dance?
    Nope, your filter should not dance around. If you have air pockets going through your system, it will "jerk" or expand and contract, but I'd look for some issue. Did you bleed air out of the tank?
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    grumpy's Avatar
    Jan 2009
    64
    Hmmm. I would have thought that the pool builder had done that. I gave it a go and sure enough air did escape. It's a little better but still not right. The pipe that leads from the filter to the heater is the one that dances most. Something else must be going on.
