28ft above ground, approx 6 years on liner.
Most likely plan on keeping the pool, walls are in good shape.
Question is if I drain this pool will the walls make it through the Michigan winter? I am pretty sure it will blow over.
(Tear is at the bottom appears 6+ inches)
I am thinking my only option is to drain and try and reinforce the walls with 2x4's till spring? Or am I taking this thing down completely?
Any thoughts and or experience in this position?
Thanks
Matt
Thanks
Matt
